trim motor running badly on raising, starting out by adding fluid to see if it fixes the issue. I have 2 spots that may be the fill hole. One is a flathead screw and the other is slightly higher, a nut maybe 14mm. Any assistance would help
f25y tilt and trim fill hole
It is the plug that is depicted in the owner's manual.
You are following your owner's manual aren't you?
Thank you very much, I know right were that one is.
And yes I am using my manual, but I do not have the diagrams you sent in my manual.
ÂÂÂÂÂÂÂÂ
