Throttle is sticky and hard to move through from idle to higher RPM and back.
Cable is new, control is loose, etc. I remove the cable from the magneto control lever and throttle shafts are sticky. Is their an easy solution to this problem? Maybe lubricate the shafts from the outside? Motor runs perfect so I don't want to take carbs off if I don't have to.
I think I know the answer to this question but...any suggestions?
