Is there anything that would cause coil packs to go bad other than just old age?
Motor is a 02 OX66 SX225TXRA.
I ask because I found #3 coil pack to be bad. Swapped 3 and 5 to test. Replaced the bad one, which was then on #5. Motor ran fine in the tub, smooth, like a sewing machine 2 weeks ago. Hadnt ran it since. Put it in the river today and lost coil packs #1 and #3. I used a Lisle inline spark tester to determine they are bad. #2, 4 and 6 all show spark on the tester at idle. #5 does not as it is a selective cylinder motor.
I have no idea if the coil packs have been replaced by the previous 2 owners. To be safe I assume they have not. Motor has 940 hours on it.
Any help and advice is appreciated. Thank you!
