Slight Oil Leak F115
  • Slight Oil Leak F115
    I have a 2002 F115 with 1450 hours on it.
    The last time I used the motor I could smell a hint of burning oil. I checked under the cowl and found some traces of oil on the bolt heads on the starboard side of the power head. I have checked under the flywheel and it is completely dry.
    There is barely a hint of oil in the lower pan and engine oil level if fine.
    Not sure where else it could be coming from . Is there any chance it could be leaking from the seal on the dip stick ? When checking the oil level it does not feel that tight where it seats.
    Thanks in advance
    JON
    It's possible to have some blow by seep out the filler tube...
    That seal should be pretty cheap (simply replace it and eliminate the potential problem).
    If it continues;
    I'd clean (de-grease) any oil residue and monitor. A spritz of baby powder will stick to any fresh oil residue.. Might show up quickly, might be awhile.
    *I bought a car with a Dodge slant six decades ago that blew oil out the filler hole, (approx 5 quarts in 20 miles-BAD). Cleaned as noted above and found that leak(dip stick hole)-engine ran great.
    Yanked the engine, turned out pistons rings were EXTREMELY WORN (1/4" ring end gap). Compression was blowing past the rings, into the crankcase, then out the filler hole. Re-ringed, BIL drove it for YEARS afterwards, no leaks, oil burning, etc...
    Should your rings be worn badly, it'd do the same.. A leak down test, would pin point that down real quick...
      no do a compression test first. what a waste of time. I cannot belive someone mentioned a leakdown test.
      but there is babypowder and NAPA sells a compound that floureces under a black light for leak detection.
        Why a compression test??
        Why NOT a leak down test if that seal is NOT the issue??
        With a leak down test, you'd hear air in the crankcase and see the actual health of the internals of the engine.
        I do them all the time(leak down)..
        Saves a BUNCH of time, even on the two strokes...
        An early 1980's, two stroke Mcculloch chain saw leak down test:
        Compression test, same engine:
        You could hear air come out the carb BIG TIME with the leak down test (motor was toast)
          I am sure Rod was just jacking around.
          He is the one that always tell us the compression test are a waist of time.
          You happened to say leak down test before compression test so he had to jack with it
            Apparently Rod is in a jacking around mood today....
              It's Friday!
