I just picked up a 2017 Yamaha 150 with Yamaha 703 binicle I believe. I want to add the multifunction tach and keep getting different part numbers from different dealers. One dealer says the 2004 and older 6YR-W0035-E1-00 kit will wire right up. Then another sent me the Yamaha tach number for 2005 and later 6Y5-8350T-90-00 with the 2 fuse gauge harness 6Y5-83553-N0-00 and the trim and oil harness for 2005 and later 6Y5-83653-20-00 the 20 number can change for different lengths.
And I looked into the older kit and the trim and oil harness 68F-82553-70-00 that one dealer said would work which it is $130 and the 2005 and later one 6Y5-83653-20-00 is only $50. Not sure what the difference is.
Also the 2004 and older kit comes with a water proof cap in the kit.
Any help is appreciated I would like to get this set up soon if someone is expirenced in these Riggings.
Thank you guys in advance.
