can anyone tell me why my 1992 55hp yamaha c55elrq leaks raw fuel though the exhaust on start up, and what I need to fix the problem, .... also, the fuel intake seems to be faster than the priming ball can handle, so at full throttle the ball will empty, and needs to be pumped up again to continue operation, and are these two problems related?...Any help would be appreciated,... thanks
Fuel leaking from exhaust on cold start
Originally posted by donnie remesco View Postcan anyone tell me why my 1992 55hp yamaha c55elrq leaks raw fuel though the exhaust on start up, and what I need to fix the problem, .... also, the fuel intake seems to be faster than the priming ball can handle, so at full throttle the ball will empty, and needs to be pumped up again to continue operation, and are these two problems related?...Any help would be appreciated,... thanks
99yam...isn't it possible to force fuel via primer bulb while engine is running, thereby keeping float needle valve open, and thus flooding the cylinders?Jason
I figured as much..my hunch is the same as the others, bad fuel pump and/or a bad needle valve in the carb...I am leaning more towards the carb.If the needle and seat are not perfect and then you add gravity from the fuel tank being above the carb/engine....recipe for leaking fuel.
See it many times on motorcycle and snowmobiles. That is pretty much the reason why many motorcycles have fuel shut off valves on the fuel tank.
Originally posted by donnie remesco View Postyes, tank is higher,.... it's a pontoon.
the fuel stops coming out of the exhaust, within a couple of minutes of operation
The faster the flow of fuel into the float bowl the quicker the pressure rises causing the valve to seat tighter. The pressure from just the elevated tank alone may be insufficient to cause the float to seat the valve. When the motor starts the fuel pressure quickly rises to a higher pressure, resulted in more fuel being supplied to the carburetor, causing the float to rise higher. The float trying to go higher causes the valve to close tighter.
Makes it seem strange that with more pressure the valve seals whereas with just a bit of pressure it may not. Counter to what conventional thinking might suggest.
This is sometimes seen in power trim and tilt assemblies. Stop the motor from going up by just deactivating the UP switch and it might bleed back down over time. Power it down for a nanosecond and the increased hydraulic pressure might result in a check valve seating that otherwise might not seat.
