does a 2003 yamaha f225 TXRB have a plug in to go on a name 2000 network to connect to a garmin?
NMEA 2000 Netwrok
Hi, I know this is an old post. Hope you can still help.
I know early Yamaha 4 stroke outboards don't have the NMEA connection, but I would think the data would still be there.
Could you provide the ECU pin outs for the NMEA connection so I am able to wire up my own NMEA data point?
Thanks.
Regards,
VicSpearo
Originally posted by VicSpearo View PostHi, I know this is an old post. Hope you can still help.
but the only way to access it, prior to "Command Link" / NMEA 2000,
is by connecting to a PC running the YDIS software.
the capability for "conversion"/"transmission" of data via NMEA 2000
was only programmed into ECMs in or about 2005
Ok, so all it needs is a reflash of the ECM and some wiring?
I have done similar mods to my car. Adding the Power train twisted pair bus to the diagnostic connector and have then reflashed the ECU/ECM with my laptop to later model software. All pretty easy stuff.
Do you have any links to download later Yamaha engine software or know of anyone doing these mods?
Vic
