OK, so I'll throw this out there for any advice:
Yamaha F20 BMH 2013 on small fiberglass fishingboat, used 90% for slow *****ing on idle. Idles perfectly smooth for hours on end. About ~130h this summer. Runs and revs awesomely on WOT (since you helped me with new prop) Has never misfired or "coughed". Starts on "2nd" pull, which I attribute to "it needs to pull up the fuel". Cold starts 100% on 2nd pull, restart on warm engine can be both 1st pull and 3rd pull due to I need the throttle set rather high to restart. All in all I've suspected fuel to be the reason for 2 pulls when cold and sometimes a 3rd when warm.
Now the recent issue: when on idle, *****ing, it has suddenly died out on me. Like a 2-3 second event with lowering rpms and cut off, just as if I would run the carb dry. Restart becomes nearly impossible It doesn't even splutter when I use starting fluid. I pull and pull but it seems almost as dead as if no spark, no signs of life. I've reprimed bulb, I can see gas in filter, opened tank to reassure no vaccuum. The stall gives virtually no warning. And after I've pulled what seems like a 100 pulls, it starts. I give it some gas and run WOT for a while. Then it can run for hours on end in idle again.
My uneducated guesses are: carb float and needle gets stuck during prolonged idle or fuelpump malfuction on low revs for prolonged time?
Next time it happens I was thinking of unscrewing carb drain to see if bowl is empty, but other than that I don't know how to diagnose?
Any help is as always welcome, sorry for a rather long question.
//Merc200, sweden
//Merc200, sweden
