N2k Engine Data from 2004 f150
  • N2k Engine Data from 2004 f150
    I have a pair of 04 f150s.
    I would love to add the engine data integration.My motors currently do not have the white NEMA 2k plug that you need to do so.
    Does anyone know if I were to buy 2 of the superseded wiring harnesses that has the N2k plug and replace my current harness would the data be fed to the plug or will the older ECU not transmit that data?
    Thanks in advance.
    You need both a later harness and a later ECU.
