loaded a friends truck and trailer with roofing supplies and food/beverages last night,they should make Marathon sometime this afternoon.
Irma....
Well, I now live on the beach!
First pic taken today. Other pic's were from 1-15-18:
Still have the davit bases that need to be jack hammered smaller. Darn near tipped the excavator over..
[url=https://postimg.org/image/u6vwh5jab/][img]
Originally posted by dray0151 View PostIs each persons wall a separate unit or how do they tie your wall back into your neighbor's walls?
The pic below, it's a tongue and groove system. They simply "jet" them into the canal bottom(with the help of the crane) and all slabs actually slip in together making one interlock with the next. This slab is one of maybe 4 in-damaged and was under the patio.
All should have been able to be removed this way IF they didn't fail..
The heavy "wires" you see is HD re-bar. It's initially tied into the concrete wall cap, extends into the back yard, then they dump a couple of yards of concrete to secure it. The "dead-man" is probably 6-8' deep placed approx. every 5' or so...(not sure exactly)...
Originally posted by dray0151 View PostDo they seal the tongue and groves with something to keep any water from invading? I'm sure they are probably tight but water gets in everywhere.
At the time of the install decades ago, I didn't see the process as I had to work. Learning a bunch now. Dunno if you can tell, but most of the failures were about 3' below the cap. The additional 5' of slab (most under ground) was fine with most of the others..
That machine snapped the slabs like an oreo cookie...Un-real...Scott
Their moving their front end loader back onto the barge using my OLD davit pads(about 4.5' around and friggin HEAVY) to support and keep the loader from going in the drink! UN-REAL!!!
Then, after being on the barge, picked up the bases and put them on the barge.
Finished installing the last couple of slabs from the barge.
Originally posted by pstephens46 View PostWhat is the guy in the water behind the wall doing?
Two guys doing that (a pretty low water level easier for them).
They have about a 5' long, 3-4" diameter pipe on the end and that ENTIRE "wand" was under water. Pumps some serious amounts of water..
IE the slabs are that deep into the canal bottom...
**Re-looking at my pic, the walls already in. In this pic he's putting in a material that allows water to flow out inbetween the slab's but NO dirt. That material is then covered inside the wall with a water BASED "tar" . So there's numerous "black stripes" of that material currently at each seam...Last edited by TownsendsFJR1300; 01-19-2018, 09:50 AM.Scott
looking at the pic it looks like that section he is working at is lower than the rest for some reason.
Is it?
I was wondering how they could jet in a slab that wide.
I would have thought they would use more than one or two jets to get it down evenly.
I guess you just have to have the guys to keep them moving back and forth
do the slabs have the holes inthem for the tie backs or do they drill them after installingLast edited by 99yam40; 01-19-2018, 10:22 AM.
Originally posted by 99yam40 View Postlooking at the pic it looks like that section he is working at is lower than the rest for some reason.
Is it?
The bucket machine holds the slabs up with two re-bar hooks in each slab. Then they use that one large jet to blast canal bottom away. They jiggle the slabs and it slowly drops down to their string line.
Every other slab has a "dead man" (yard or #? of concrete) set into the ground (in-land and deep). Re-bar is buried in that and that runs up to the cap.
As there's already dead men in there already, (every other one), they NOW use the adjacent(new) slabs to put the cap/rebar above. The cap is formed (with re-bar-pic's to follow Monday) above the slabs and extend down (I'm guessing 5" down BELOW the slabs)- Once all the re-bar is in, ran to where the dead man is poured, all that concrete links EVERYTHING together.
The slabs NOW have sealed re-bar in them, the old ones did not(thus all the rust inside). The cap is 7,000 PSI concrete as well
So the cap ties everything together with covered re-bar back inland and deep to poured concrete. The old dead men NEVER MOVED. The slabs failed and blew out about 3' down from the cap... There was still 5' of slab(some very broke) down past the water line buried into the canal bottom..
Post image is down right now so can't add any pic's.Last edited by TownsendsFJR1300; 01-19-2018, 08:13 PM.Scott
ÂÂ
