Help with water leak
  • Help with water leak
    Hi all I have a yamaha 4hp 2stroke unsure of year as it has no I'd plates. I noticed when it's running the water from the pee hole is not continuous it kind of spurts out. When the engine Is reved there seems to be water coming from the lower cowling where the gear lever is. I cant see where the water is coming from. I've removed the power head and the gasket seems to be fine. Any ideas will be very much appreciated.
