I have a 2006 F150 that I replaced the water pump on, I did not try to start it before but now it will not crank, no gauges no fuel pump all that works is the trim. I have tested the netural saftey switch, did a load test on battery, tested fuses, have not tested the starter relay. I dont know want else to test. HELP..
2006 F150 wont start.
Did you check to see if there was power to the starter motor?
I would guess you don't...
Connections and wiring are most likely your issue.
What kind of boat? Where are batteries located?Last edited by pstephens46; 08-30-2017, 07:09 PM.
I'm guessing now, but everything that doesn't work (except the T&T) goes thru the ignition switch.
I'd be checking the wiring at the ignition switch
The T&T will work as long as there's 12 volts to the engine (and doesn't need the key on to work)
Someone else will chime in more knowledgeable about electrons...
.Scott
