click the private messages
set incoming or sent folder
click on the right side window of each one you want to go away.
then click on one of those messages
it will give you the option to delete at the bottom.
click the box delete this message
then click the very bottom delete message and all of the ones you marked should go away.
lot easier to just empty folder tho.
why keep some of them?
