I got this older gauge (Yamaha part# 6Y5-W0088-70-00) with a very nice used 2008 F225 I purchased from a good friend.
I've got it all working but can't get it to pick up GPS data for speed over ground from my Lowrance HDS gen2-8". (It will display water speed when I connect it to the water speedo pickup tube.)
I don't know if my problem is (a)my NMEA0183 connection to the HDS, (b)programming my HDS to transmit GPS info. to the gauge or (c) maybe programming or DIP switch settings on the gauge so it will use GPS info for speed rather than the water speed info.
Does anyone have a similar working setup?
and/or
Can anyone provide me with the original Yamaha install and operating instructions for this gauge?
Big thanks in advance!!!
and/or
