Originally posted by Tony Harper
View Post
T60 TLR shutting off
Originally posted by 99yam40 View Postfuel should not flow back to tank with the motor/fuel pump running
As for the cracked OEM, fuel filter mount, (and the info posted), plus 100 on that, especially with it being so tight.
The crack would have started small and eventually grow, just like the issue was once in awhile, and is now worse.. Larger crack, more leakage..
.Scott
Originally posted by Pacific76 View PostAh copy that and thanks for clarifying. It was screwed down so tight when I replaced the filter ended up removing the whole element just to get it loose. Understandable how those can get a crack in them
Ran all day without any drop or shut off issues happy to report
Before run, I did check the black lid on fuel\water separator by pulling off again and inspecting fully apart. No cracks found
The last thing I did was install four new plugs
Part#NGK-DPR6E-B9
Only time will tell if any problems are to return. For now I'm back on the water
Â
