brass/copper do not go well with aluminum, that is why they use SS in aluminum .
but SS does not get along well either, but is a lot better than copper
Looking at those pics they look like straight thread fittings. I would drill and tap for a helicoil insert. You might want or have to take it out some day....
Do it right.
Panasonic is hereby elected the official "Threadman".
All this tap stuff...starter, bottoming...I don't know.
There is British Standard Pipe Tapered and National Pipe Tapered
but AFAIK there is no such thing as "metric tapered"
Fairdeal you are absolutely right. The Japanese adopted the British Standard Pipe Thread for their manufacturing, along with rest of the metric world...lol
The USA came up with their own...National Pipe Tapered
The starboard side already has the brass fitting installed for the water pressure sender. It was there when I bought the boat and it looks like it's been there for a long time. So brass fitting seems to be working fine. I just confused why I should take it off the starboard side and install it in the port side if I install the temp sender.
Go back and read the illustration that is within your own post #12.
What does it say?
But it is your motor. You don't have to do anything. Do what you want to do. Rig it however you want to rig it.
What does it say?
Yes I see that, but the water pressure sender is already on the starboard side, so I guess my question is why would it break the tube if water temp sender is added? I'm just wanting to know for piece of mind.
