Originally posted by cleddau1
View Post
FT9.9 AE X Cylinder head removal
do race saws have more than one cylinder?
never even looked at one myself, but watched some on TV in the past/
the blowers are loaded as much as they were designed for with the fan
but weed eaters are designed to hit weeds and not just spin the line
yes 4 strokes are different than 2 strokes
forgot this was a 4 stroke thread
what vacation?
Originally posted by panasonic View PostWhat do you mean you only hit the Rev limiter once? That bike will wheelie starting at 50 mph....they are rocket ships.
It's an upright sitting bike, regular handle bars-actually with bar risers/set backs. (I don't do the lay down thing).
The engine thou is a slightly de-tuned R6 (GO-fast bike) engine.
Hit the rev limiter once in second gear, about 90 MPH (6 speed). First gear picks up the front wheel (don't like to do wheelies either, it hurts if you screw up) at about 8,000 RPM.
The engine is very tame under 5K, 6K and up, (with aftermarket pipes), it "wakes up" and is a very different bike, "coming on the pipe". It does sound like a 1000cc go fast bike past that 6k RPM.
About 47 MPG around town and usually 95% of the time, under 6K RPM's.
2007 model, about 25,000 miles now..
C'mon boys do you really believe I would rev an engine to max unloaded, especially one I had just partially rebuilt? However I should have been more specific. When held at just above 2000rpm it misfires. The reason was that when refurbishing the head I had put in some old spark plugs to protect the threads. New spark plugs and some adjustment to mixture and engine is fine.
Any comments on the compression?
Many thanks for the all the advice and encouragement.
Big tides at 7.4 metre range due to proximity of moon so yesterday used human power to kayak the Eastern Cleddau as far as the Weir. Favourable tidal stream both ways so mostly doing over 4kn, almost as fast as my sailboat........
what was the compression before you took it apart?
115 sounds good for 2 stroke.
but I thought that the 4 strokes had more compression than 2 strokes,
but with all of that carbon in combustion chambers, maybe the rings are carboned up too
has anyone here run a compression check on a F9.9 to give him a comparison?
Tides down here are just a couple of feet.
half the land down here would go under if we had 7 meters
I bought a training kite for kite surfing, thought I could use it to pull me around in my kayak.
no good way to launch it on the water.
so it is just a play toy when I can find open areas and windLast edited by 99yam40; 10-09-2017, 03:47 AM.
No carbs here so maybe no help. Surprised Yam or someone hasn’t commented. Guys, what is the pot? device on carb that poots a little more fuel into carb when suddenly pulling back on throttle? Just a faint memory as the older conversations didn’t apply to me. Not sure his carb has the thing.
Originally posted by pstephens46 View PostNo carbs here so maybe no help. Surprised Yam or someone hasn’t commented. Guys, what is the pot? device on carb that poots a little more fuel into carb when suddenly pulling back on throttle? Just a faint memory as the older conversations didn’t apply to me. Not sure his carb has the thing.
Thanks for replies, will run another compression test when I recommission engine after winter lay up. Premature throttle valve closure sounds a logical explanation for my problem. However there is nothing on the engine looking like the dashpot on the triple carb diagram and as you all know this a single carb engine. Is there any other adjustment on the carb that alters the rate of throttle valve closure?
