I have a 2005 F90TLRD with a bad trim motor.
Boats.net identifies a replacement yamaha trim motor as part number 6D8-43880-00-00.
I found a much cheaper aftermarket one on amazon which says that it replaces part number 6D8-43880-01-00. Are these equivalent part numbers?
Also, the amazon part says that it is for a short shaft application. Howe do I check if my engine is a short shaft?
