will not start hot
  • will not start hot
    I have a 25 hp 2009 yamaha outboard that starts fine with the key. When I run it Ann cut it off, then it will not do anything with the key. I can pull the rope one time and it cranks and runs fine. Once cold it cranks by the key.
    Thank you for the information.
      a complete model # and an explanation of what you mean by" it will not do anything with the key "will probably help
        I did not see a question being asked. Am I overlooking something?
        With regard to the statement I am a bit perplexed. Title says will not start. Body seems to imply that it will not crank when the key is turned to the start position.
        What am I missing?
          I just want a clarification of what he said
          just saying nothing happens does not say much.
          plus the need for model #
            Sounds like a weak battery or poor battery cable connection....check those carefully....remove each cable, inspect, clean with wire brush, a dab of grease and tighten back....
              Putt the key in the key hole and then turn it
                Guess we won't get a model # ... I see at least 3 dozen engines, two strokes, four strokes, ALL 25HP...
                Please either answer some basic questions or expect no useful answers.
                "Turning THE KEY" to CRANK/SPIN it over I'll GUESS?? Or just to the run position?
                  and I deal with this everyday sometimes many times a day.
                  I have gotten good at 20 questions.
                  not as good as my wife but I am working on it.
                    rodbolt17;145433]
                    and then you will retire!!!!
                    Dennis
