2002 z200txra
    2002 hpdi
    Just followed shop manual. You pull a fuse and then connect a battery and then check for continuity
      With a battery in the system you would be checking for voltage being present.
      Continuity to me means using the Ohms setting without voltage present
        2002 hpdi z200txra
        Would send pics of shop manual but don't know how
        • #19
          2002 hpdi z200txra
          Installed fuse holder and runs better but still missing at wot. If I back off of throttle it runs great. Push throttle the last inch and starts missing and loosing rpm if I back off throttle it picks up rpm. Maybe just run it till it blows.
          • #20
            2002 hpdi z200txra
            Took boat to dealerwill report what they find I think it's the ecm
            • #21
              sounds like a fuel problem
              • #22
                2002 hpdi
                Dealer had hp pump rebuilt runs good now .
