I noticed that when going from reverse to neutral, the binnace clicks and the electronics (key switch) thinks it's in neutral. But apparently the drive stays engaged in reverse. If I go to forward and then back into neutral it goes back to true neutral.
We'll as a test I put the boat in forward and then Neutral and marked where the lever was. (Black mark)
I then put it in reverse and then in neutral so I could see where it was stopping.... see below. Seems that the cable might have a bit of slack in it... the grease is from me just in case it was sticking because it needed lubed. It did make it move easier. But still didn't disengage reverse.
So the question is - can the cable be adjusted to solve this issue on this set-up? Better just going for replacement? Or is here another potential issue on these motors?
2001 SX150TXRZ
Thanks!
2001 SX150TXRZ
Thanks!
