2001 F115 Yamaha fuel injectors not squirting????? stumped
      Now that is some good info thank you boscoe!!!
        Finally picked up the boat and found a real certified yamaha tech. He also stated that the stator is bad. he tested it and said just a few days till its finished.
        • #19
          I would be interested in what part of the stater tested bad to cause no signal(ground) for the injectors and what was the bad reading
          • #20
            all BS.
            the only function the stator has on an F115 is to charge the battery.
            the stator has no ign functions.
            • #21
              Without going overboard...no pun...have you checked to see the lanyard switch is actually working? Does it crank but no start?
