Trim issues 40 2 stroke 01
  • Trim issues 40 2 stroke 01
    TT not working no clicking sounds, can I directly operate trim motor by jumping power to blue or green cables on the relay? If so how do I make connection
    epidemic of trim issues...
    when blue gets power, green ground, it goes up
    when green gets power, blue ground, it goes down
    you have right there on the relay - larger size wires:
    motor leads - green, blue
    power - red
    ground - black
    simplest is to disconnect the motor leads,
    then touch one to red and one to black
      It is best to disconnect the wires before jumping with power because the relay should ground when in the de-energized position.
      Jump with them still hooked up and the + you put to one of the trim motor wires should be going direct to ground at the relay
