I need to lean on you again for a little advice re: my 2003 F225TXRB 69J X 1003602 Q (Canada). It’s an EFI with 209 hours. Fresh water only. It is unlikely I will tackle a repair myself unless it is very straight-forward. I do not have the tools (e.g. software) to check things out in detail.
My objective is a little education before I see my local Yamaha dealer. If you feel this has been described in detail on this forum - please point me to that place. Or you might suggest that I go straight to my dealer which I am OK with.
Recently the engine is -sometimes- hard to start. Rarely it starts on the first try. Often it takes maybe 4-8 “tries” to get it going. What I mean by “tries” - I start the engine, it runs for maybe 2 seconds and stops. I do this over and over until it starts and keeps running. Pumping the primer bulb makes no difference in my experience.
My basic config is Gas tank -> Racor secondary filter -> Primer bulb -> Yamaha Primary filter.
Possibly related: Once this year after running for about 10 minutes at idle in gear heading out, the engine started to shake and it stalled. I could not restart it. Of course it was in a busy channel. So I just threw out the hook and began to investigate. I noticed the primer bulb was hard as a rock, which it never is. The fuel line appeared slightly kinked at the bulb which I straightened. I sat for maybe 15 minutes and investigated again. The primer bulb was now soft. I tried the engine - started right up. No problems like this since.
I have now read various threads related to the VST and lift pumps. One thread seems really close, but owner only has a problem on first start. Mine has nothing to do with first (cold) or subsequent (hot) starts. I now understand it might be air in the line on the suction side, lift pump or maybe a sensor.
My Action Plan: 1. Replace Primer Bulb. 2. Check for air leaks on suction side (inspect hoses, primer bulb). 3. Check primary fuel filter at startup (is it going dry?). 4. Add a piece of clear tubing before the lift pump as described elsewhere on this forum to check for air bubbles (is clear metric tubing going to be a challenge?) 4. Stick a fork in me.
Thanks in advance for your feedback.
Robin
Robin
