check the thermostat for proper operation
1990 Yamaha 225ETLD oil pump disconnected
we can mostly rule out oil coming out the carbs,maybe premixed spit back and the hose from the airbox to the lower crank bearing is unhooked. the oil is injected ito the reed box area.
like I say I do a consumption test. the output spec and rpm is in the SM.
multiply it by six and the consumption equals the output.
Originally posted by rodbolt17 View Postwe can mostly rule out oil coming out the carbs,maybe premixed spit back and the hose from the airbox to the lower crank bearing is unhooked. the oil is injected ito the reed box area.
We are talking about the line that connects to the bottom of the airbox correct? Item 26 in the diagram.
http://www.boats.net/parts/search/Ya...AKE/parts.html
