Hi all,
on my Yamaha F115 2009, I made a scan with the Yamaha Diagnosis System, and you can find attached the results. Basically the Throttle Valve Opening is out of range when the RPM are between the idle and 1500 (from -3.8 to 0). Over 1500 RPM everything is fine.
In the Service Manual I found this:
ADJUSTING THE THROTTLE
POSITION SENSOR
Throttle position sensor output
voltage (pink (P) – black (B))
0.732 ± 0.014 V
Measuring steps
(1) Remove the intake silencer. Refer to
“INTAKE ASSEMBLY” on page 4-3.
(2) Disconnect the throttle joint link rod 1
at the throttle body.
(3) Check the throttle valve.
(4) Connect the test harness (3-pin) as
shown.
(5) Connect the digital tester probes to the
test harness (3-pin) as shown.
(6) Turn the engine start switch on.
(7) Measure the output voltage.
(8) Install the intake silencer.
(9) Start the engine and measure the output
voltage again.
Adjustment steps
(1) Loosen the screws 2.
(2) Adjust the position of the throttle position
sensor until the specified output
voltage is obtained.
(3) Tighten the screws.
(4) Connect the throttle joint link rod 1.
Am I on the right way doing this?
Thanks!
POSITION SENSOR
0.732 ± 0.014 V
Measuring steps
shown.
voltage again.
Adjustment steps
Thanks!
