My 2001 90 TLRZ is having spark/ignition issues. Plugs 1 & 3 will spark for a split second when first turned over and then will quit. I have tried unplugging the white wire at the bullet connector with no change.
I then tried unplugging the yellow wire for the emergency circuit and the motor fires right up.
My question is where should I begin testing and what parts does it being able to run on the emergency circuit rule out?
Also, could a bad Crank Positioning Sensor be a culprit? Visually inspecting it, it looks like something must've gotten between it and the flywheel because it looks like something had rubbed against it?
Thanks for any help in pointing me in the right direction
