I have a 2000 Yamaha OX66 150HP. I was changing the water pump and broke that plastic nipple that the speedometer tube connects to. In the process of digging it out of the hole, I boogered up the threads. Anyone know what size those threads are? Thinking I will need to run a tap down there to clean it up. Appreciate any help or ideas.
Broken Speedometer Nipple LowerUnit
Yes, that was my fall back plan. I will have to get the new part. I'm assuming it's a metric thread and since there aren't a lot of metric taps easily available I was hoping someone might have that answer at their fingertips. This seems to be a pretty common issue.
Not really a common issue, but S... happens.
Someone might know but your post is the first I've read here asking...
Think this is the correct one: http://www.boats.net/parts/detail/ya...378-00-00.html
Good luck.
.Last edited by TownsendsFJR1300; 07-17-2017, 07:35 PM.Scott
The nipple has tapered pipe thread on it....so I would assume the hole that it screws into is also Tapered pipe as well. Now it being a Yamaha I have no idea what size it would be... cause everything is metric.
So you will need a tapered pipe tap the correct size and pitch.....hmmm
What size hex is on the nipple...10mm 0r 12mm?
If the threads are not too terribly boogered up, perhaps some good teflon pipe tape on the fitting to help it turn into the "iffy threads"?
There's not a bunch of pressure on it and your just tightening it down till snug..
A quick peek on Flea Bay, : http://www.ebay.com/itm/HSS-M1-M16-I...QB6JTeWbUvhdLQ
Tapered, metric taps are pretty common...
.Last edited by TownsendsFJR1300; 07-17-2017, 08:18 PM.Scott
Originally posted by TownsendsFJR1300 View PostIf the threads are not too terribly boogered up, perhaps some good teflon pipe tape on the fitting to help it turn into the "iffy threads"?
A quick peek on Flea Bay, : HSS M1 M16 Industrial HSS Metric Taper Plug Tap Right Hand Thread Drill Bits Set | eBay
There isn't really a "metric" tapered pipe thread as far as I can tell. The Japanese adopted the BSPT "British Standard Pipe Thread" for their manufacturing. From looking at the fitting in the parts picture Scott posted and I had one out good while ago.... I "think" it is an 1/8" -28 BSPT thread on the fitting.
1/8" British tapered pipe threads will have 28 thread/inch, vs. 27 threads/inch for NPT (standard). Pitch diameters at the small end/lead thread are within a few thousandths of each other. The other big difference is the thread form (55 degree Whitworth vs. 60 degree sharp vee).
Here is the tapered tap from my Blue Point "metric" tap set.
I would get the fitting in hand and check the threads per inch with a thread gauge and then source the tap, Maybe Mcmaster-Carr?
Maybe call Yamaha tech support?Last edited by panasonic; 08-14-2017, 07:16 PM.
the end of the barbed fitting with the threads is tapered, think air hose fittings, pressure gauges, brake line fittings, ect ... So the hole that fitting screws into is tapered as well. The fitting wedges itself in hole as it tightens...self sealing.
Those "tapered" taps on EBay are just for straight thread holes but with a taper on the end to help start the tap square in the hole when threading..
Good tap sets have three of each size tap, for example see the picture for a 5/16"-24 UNF tap.
There is the Taper (or starter tap), the plug tap (middle) and bottoming tap (to get down to bottom of blind holes)
Most tap sets only come with a plug tap for general use in each size....Last edited by panasonic; 08-14-2017, 07:16 PM.
I agree it should be self sealing (and no tape/sealer needed). Just being used strictly for "lubrication purposes" to limit damage to the new plastic fitting going into "dis-figured" threads...
And if that is the correct fitting (the link I posted), that fitting isn't very tapered at all.Scott
Originally posted by TownsendsFJR1300 View PostYep, that one link looked like a regular tap VS yours which is VERY, obviously tapered.
So the hole it screws into will be a Tapered thread, created using a Tapered Pipe Thread tap of the correct size.
That is what I am trying to determine...what size? When it comes to tapered pipe fittings things get weird.Last edited by panasonic; 08-14-2017, 07:16 PM.
Originally posted by 99yam40 View PostI do not remember seeing 3 different pipe thread type of taps in sets here in the USA
They just have different ends on them for starting the thread, through hole or bottoming hole. They are not Tapered Pipe Taps.
The second picture is a Tapered pipe thread tap.
