I have a Yamaha 40, 2004. It has started "idling" at 2400 rpm. I replaced the thermostat today as the rubber had cracked. High idling can be a symptom for a stuck thermostat . After that the engine was normal, idling at 7-800 rpm and we took it for a test run. 1 km at full throttle, then idling, stopping and starting as normal. New 1 km run. And then the high idling returned, more persistent than ever. I notice some blue smoke. Can problems with the electrothermal valve result in high idling?
How does the engine govern idle speed?
