Tilt/Trim slowly leaks down 90HP 2 stroke 2002
I have developed a problem with the Tilt/Trim not holding position. It slowly leaks down. I have no fluid leaks and T/T works up and down. Fluid level is OK and fluid is clean. There must be a bad O-ring that is bad causing internal pressure equalization. I am new to this but I would guess that it is associated with part 39 (2 of them). Maybe even parts 50-57. Could someone explain the purpose of those valves? I know 50-57 is the manual release. I am not sure about 39.
Thanks in advance,
Jim
Thanks in advance,
Jim
