no spark means the lanyard is working. make sure the brown wire to the ECU or the DES switch is connected.
the ECU controls the grond path to the horn VIA the pink wire in the ten pin main harness.
if the ECU detects a start signal and a stop signal it inhibits spark and grounds the pink wire, yellow is key on power for the horn and other functions.
