basically it says that if the output of the CDI meets peak voltage spec and you still do not have spark then it has to be in the ignition coils or wiring to them.
the CDI is good
the CDI output does not meet the minimum 130 spec,
charge coils do meet the 60 and 100 minimum spec,
the pulser meets the 5 v minimum spec but 13v is over spec so they say to replace the CDI
it is very confusing to have to look at all of your pics to see the readings you got, but it at least lets me see what the manual says
manuals have been printed wrong before, but I have no idea if this is wrong or not.
maybe Rodbolt or Boscoe can help with if that is correct
the CDI is good
