Yamaha 2 stroke issue
    Brothers C60 had a air leak at the filter Oring,sucking air.
    pumping bulb good and tight pressured it enough to spot a fuel leak
      Well, was gone for a couple of weeks and decided to try out the yammie a few times before posting again. It finally 'acted' up while the mechanic was doing a test ride. A line from one of the carbs to one cylinder was blocked and so they rebuilt the carbs (pricey). Their theory was that the 'blockage' moved intermittently until it finally lodged firmly in the line and that the 'stuff' had probably been 'accumulating' over time. So far so good - this 130 starts, idles and runs strong.
      Thanks to all responders -
        Glad it's running...
        Apparently their "earlier check" of the carbs apparently wasn't very in depth...
        • #19
          .... wcis ....
          • #20
            Originally posted by hauntedbywaters View Post
            .... wcis ....
            Ok, what's "wcis" ?
            • #21
              lol. sorry. "what can I say"
              • #22
                Thanks.........
                • #23
                  us old farts have to guess what the younger people try to say
                  • #24
                    You know it takes too long to type (don't get me started on grammar, etc)...
                    • #25
                      did they come from Newfoundland??????
                      Dennis
                      • #26
                        My fault - full disclosure necessitates the admission that I used to have an 8 track player ...
                        • #27
                          I still have a rotary phone....
                          • #28
                            do you still use it?
                            I have a 8 trac player also, no tapes that I know of, but use the radio some times
                            My sister has the old hand crank telephone from Grandma's house.
                            one does not do much good
                            • #29
                              Naw, just kidding, BUT I do still have a Kenwood Record Player in the closet.
                              The stereo (separate components) is from the early 80's, speaker paper disintegrated many years ago.
                              Found a guy that was able to get the main amp/equalizer going again. That and new Cerwin Vega speakers (top of the line) and it'll rattle the windows!
                              A CD player is what I usually run...
                              • #30
                                Record players....it was a whole thing with the needles and the cartridges. All the fuss about weighing the thing to determine the correct pressure, needle on vinyl. Like points, too much trouble...
