Took the boat for a spin (very windy and choppy seas) and noticed that a few times the starboard engine rpm's were all over the place (up to 4,600, down to 2,300 and so on). As soon as it happened, I put the engine in neutral and then back to the required rpm's to match the port engine and this worked for a while but eventually rpms started jumping all over.
Can you give me some suggestions as to what to check that may be causing this rpms' behavior? FWIW, I had some issues with the throttle cable in this engine, my mechanic made a temporary fix while a new cable arrives.
TIA
TIA
