F300 ISO lead hookup
  • F300 ISO lead hookup
    I have twin 2016 F300s. Only the starboard motor has an ISO charging lead hooked up to the house. I want to add an ISO lead from the port motor to the house battery as well.
    I didn't stumble across the Pre made Yamaha kits for this before I ordered battery cable, connectors and a 100 amp breaker from Pacer.
    Do I need a Yamaha part (special connector) where the cable connects to the terminal on the F300?
    100 amp breaker? Sounds a little stout for that job.
    Yes it is a special connector.
      Thank you.
      The Yamaha part includes a 100 amp breaker for 4.2L and had a 100 amp fuse on the engine/Ecu side. The factory installed lead has a 100 amp breaker. The max output of the alternator is about 70 amps.
        Sounds to me like you want to make your own cable. If you are in search of a connector that you can add to your cable, so that it interfaces with the Yamaha connector on the engine harness, this is a place to try to find it.
        Sealed
          Sealed
          Great! Thanks!
