I have a 2005 Yamaha F90 TLRD with almost 500 hours.
During cold engine startup, my engine will frequently stall within a half second of starting. Once the engine is warm, there are no startup problems.
If I open the throttle a bit during cold startup, the engine will start without a problem. If I then drop the open throttle down to idle too soon, prior to letting the engine warm up a bit, it will also stall sometimes.
Once warm, the engine starts and runs great. Reaches almost 6000 rpm. No codes with yamaha diagnostic software (although some history). Compression tests of cold engine were good at 170, 175, 185, 175.
Fuel pressure is strong. I actually measured about 5 psi over the values in the service manual. The pressure gauge I used is old so I am going to confirm this with a different pressure gauge.
If I do the yamaha diagnostic stationary test on the IAC valve, I can hear the valve move, and then click at the end of the test. I also hear the IAC valve click when I shut off the engine. However, if I do the engine active test of "fully open IAC valve", the engine will stall every time.
What do you think the problem can be? Do you think it is the IAC valve? They cost $250 so I don't want buy one unless I am pretty confident that it is the problem.
