I need to raise the pinion gear a bit on the forward gear. What keeps the pinion gear from dropping down too low on the Forward gear? Guessing I need maybe a 1/16". As it is, it binds a little before turning then rumbles or grinds (gear noise) when rotating by hand. Probably something stupid simple, but...??
1988 4 hp 2 stroke Yamaha lower unit
being just bushings on the drive shaft and a plate washer, maybe a thicker washer , bushing bad or set wrong, housing messed up.
hard to tell from the parts breakdown what that bottom bushing is built like
I bet there are not many that have played with a 4 hp from 88.
what happened to this thing that caused you to take it apart?
what happened to this thing that caused you to take it apart?Attached Files
Maybe Rodbolt will chime in.
not sure he works on the small motors much, but he may know how the bushings and other parts hold things in position.
(what sets the clearance)
I my self do not know what could put enough upward force on the shaft to snap off the end of shaft the clip sits in and push the pin in Water pump up thru the metal housing
