Think I have it figured out
Checking all connections this morning and the bolt that holds down the pulser coil has worked its way loose almost falling out, I'm sure that would cause the codes etc
Challenge is getting it tightened w flywheel on, may have to remove to get to it
Something so simple but will be happy if this is it!
