On Saturday my starboard 2009 f250 was running fine for about 30 mins at high Rpms then powered itself down in safe mode not allowing more than 32-3400 Rpms, not enough to stay on plane. Check engine light came on but no overheating or oil pressure alarms or beeping etc. turned it off and on several times but never could get it out of safe mode. Back home on trailer held the mode button down 10 secs and it gives the 01 code, which means all ok.
Does the motor have to be running to show the code or just the key on? Was expecting a code for cam sensor or fuel pressure cause I thought the low pressure fuel pump could have gone out. 1,100 hours
Something else but this sounds dumb, I have not reset the maintenance reminder on the gauges last few times I did my 100'hour services. Would it put it in safe mode if it gets so many hours beyond 100 ?? Port motor is fine
Appreciate the help of course shop is backed up so hoping it's something simple electrical a sensor etc
