A result
Part replace yesterday and water tested with good results. But I don't really think I have found an issue. Here's a list of what I did.
1 replaced water separator ( thought I crushed gasket)
2 primer ball
3 tested vst vent and swapped it with good motor
4 low pressure (lift pump replaced
5 pressure relief valve and tube replaced.
I don't know if I had more than one issue
If the issue comes back I don't know where to go next . I hope this helps others with this issue. And thanks to all who responded. Well its time for a new thread.
2 primer ball
