So the first thing that you think I should try is to put the clear plastic tube in and look for any air bubbles? Also what the fuel water cooler I just would probably disconnect the hose and hook the motor up to the flush port and see if water flows through?
Fuel starvation yamaha f225 i need help
I do not remember what motor it was, but not long ago there was a motor that had a plugged cooler outlet that ran under the power head . the cooler itself was clear, but they finally found there was no flow because of the plug where it went back into the motor .
I have no idea how this 225 is set up ,so thought I would say to make sure there is proper flow when running.
(May have been a F60)
OK I'm gonna start moving the holes around when the motor ran I had fuel passing through the pressure release valve.I also emptied the VST tank and it appears to be full I had over I probably over 9 ounces a few on there.I pulled out the pressure release valve it took quite a bit of pressure to get it through but I did have a slight drip out of it
Originally posted by marchmadness View PostOK I put a plate of clear plastic tube between the onboard fuel filter and the white connector it filled with fuel after I shut it off it drain backwards I believe because now the clear plastic tube is empty
does if show air bubbles on the other side?
Originally posted by marchmadness View PostI took a video but I don't know how to post . But it looked foamy going in. The other side had bubbles looked better when I changed primer bulb.
Takes a lot of air to make foam.
[QUOTE=marchmadness;142111]I took a video but I don't know how to post . But it looked foamy going in. The other side had bubbles looked better when I changed primer bulb.[/QUOTE
Foamy going into the filter?
or something else?
as I said before you need to find out where the air is getting into the fuel system.
Is the another water/fuel separator/filter before it gets to the motor?
ÂÂ
