Bought a used 1993 90 HP two stroke yamaha that has been in storage for some time now. I took the boat out today and noticed that the motor was running very slow even in wide open throttle. When I put the motor in neutral I can hear the motor reving up as if I was increasing the throttle. Does anyone know what might be causing this?
Also, I can hear a very bad grinding noise when I put the motor in reverse. I suspect this may be a sign of a bad gear case but does that contribute to the problems mentioned above?
