Fuel Management gauge installation guide
    I would also appreciate to get these instructions on info@tema-consult.com . I am trying to connect Garmin GPSMAP 185 to Yamaha Fuel Mgmt Gauge 6Y5-8350T-82-BK.
    Thanks in advance
      Thanks in advance
      Sent you a copy.
        please send me any info with Yamaha FMG GPS wiring
        Hi I am trying to connect my Garmin 2006 c speed data to the Yamaha fuel management gauge. I need the dip switch location (is it behind the rubber hub and what should each be set to settings, the gps info out (blue )I believe and also the shared ground info. Ay help in addition to what I've already read would really be appreciated . Any wiring schematics would be wonderfull.
        Thanks in advace,
        Triton424@mac.com
        • #19
          Could I also get a set ??
          Thanks in advance
          roryorkin@verizon.net
          • #20
            Fuel management system
            I also purchased a system can you send me a copy to jramosstcld@aol.com
            • #21
              Fuel Management Manual
              I recently purchased a 2002 Contender with the Yamaha fuel management gauge. The gauge does not work. I would greatly appreciate a copy of the manual for the fuel management gauge to attemp to determine the cause of the problem. Could you send it to taxadvice3421@yahoo.com.
              Thank you, JR
              • #22
                I emailed you a copy.
                • #23
                  Sorry to trouble you but I ned the document if it is possible.
                  ibaezpardo@yahoo.com
                  • #24
                    Hello sorry for time waste, but I need a copy of this precious document to corradob@gmail.com
                    • #25
                      instr and parts
                      I also need the instructions, please. And I think I need the wire harness and fuel sensor. Where can I get these? Thanx for any help
                      • #26
                        I would also appreciate a copy to troubleshoot my FM gauge. Please send to
                        hh@waypointproperties.net
                        • #27
                          fuel gauge
                          Forgot my e-mail address for above.
                          Thanx
                          Tom trhills@alaska.net
                          • #28
                            Fuel Management Gauge
                            Can I get a copy of the manual please? msilva@ctilabs.net
                            thanks.
                            • #29
                              Saltydog
                              Can I get also a copy of the installation instructions at the email mymail.boxes@hol.gr
                              • #30
                                Until I found this fourm, I thought I must be the only person looking for this info, as nothing else could be found on the net. I too need a wiring diagram so as to deal with the wire colors for the digital guage set. I have 2001
                                ox66 250 SWS counter rotating motors (a pair), with (2) tach's, (1) speed/fuel gauge, and (1) fuel management (dual application).
                                I have the harness for all plug in's, but the extra wires for the lights, fuel senders, etc., that are not part of the harness, on the gauges, is what I need to verify the connections for. I also want to connect the speedo to a GPS/chartplotter, which I belive I heard was possible. This too I need to confirm which wires are the correct ones for this data.
                                Any direction as to where to find this info would be greagly appreciated.
                                Henry
                                henryhauch@hughes.net:
