I have a '99 Ox66 225hp. Have just rewired the entire boat and hooking gauges back up. I labeled all wires before dissembling but I find myself with a few wires that I don't know what to do with.
On the LCD gauge, I have the white/blue stripe wire which I understand goes to the fuel sender. It has a bullet connector and I don't remember this wire being hooked up. I am installing a new tank with a Wema sender with a white and black wire. I assume the white/blue stripe is connected to the white wire on the sender and the black goes to ground on the buss???
The LCD also has two wires, a black and a white (maybe gray) that have been tied back. Never looked like they were used. The white (gray) has a female bullet connector and the black a male. Do I need to do anything with these?
On the tach, I have a blue, yellow and black wire, all with bullet connectors. I understand the blue and yellow are for lighting the gauge. Do I hook both to the nav switch or one or the other? I have also read where you can connect them to each other???
I also assume I need to clip the bullet connectors and use the appropriate ends. Any help is appreciated.
