Originally posted by rodbolt17
View Post
Anyone know what this spring goes to?
Originally posted by rodbolt17 View Posthas the world gone nuts?????
it is very simple.
loosen the bolt.
move the flywheel in its regular rotation a bit.
tighten the bolt.
adjustment is done.
yes Virginia it is that simple.
Then adjust..
.Scott
If you are good you might set the tension without the spring, but since they do not say how much tension to apply you would be guessing.
At least the OP does not have to worry about the belt being loose because the spring broke.
The bolt locks the tension .
just cannot readjust without the spring
