Hi all, Having another problem with this outboard. I had a dead computer previously, and a replacement resolved my starting issues.
However now I am having extremely high idle (Anywhere from 1600-3000RPM) and a clunky/clicking sound coming from the lower unit when shifting into forward or reverse.
The RPM climbs when I give it throttle in neutral, but doesn't fall back down at idle unless I choke it.
I only shifted into gear once at 1600, and shifted back immediately once i heard that clunking. With the choke on that kept the RPM around 500 where I felt better about shifting but still heard the same clunking noise. Not just one when shifting but continuously. I'm avoiding putting it into gear, i'm pretty sure that noise means something is going to get destroyed very quickly like that.
I noticed a loud hissing, like sucking through a straw, more noticible with choke. It seems to be coming from the Carb. Could this have anything to do with high idle?
I do have a Yamaha service manual. But i'm not sure where I should start looking.
Thank you for reading and I appreciate any help.
