2007 200 HP V-6 Shut Off
  • 2007 200 HP V-6 Shut Off
    I have a 200HP 2007 V-6, Great Motor. Have a problem recently with running fine for the first 30 minutes. After sitting for 30 minutes or more the motor cranks fine and idles fine. When I engage gear it runs fine to 3000 rpm then sputters and will shut off.
    It does crank right back up and I can raise RPM in neutral with no problem. When I put in gear and get to 3000 rpm it will stall again.
    Any Ideas?
    Has 700 hours on it and has had 100 hr service each year.
