SOLVED: Replacing the sensor assembly resolved the issue.
I've owned the engine since the beginning of last season (April 2016). On my first trip out this year (April 2017), it ran extremely rough at first. I expected this, because I know the fogging oil needs to burn off. After a few minutes of running at almost full throttle, it started to behave normally again. It idles around 740-750, revs to 6000 rpm at full throttle with a full boat load, planes quickly like it always did last year, etc.
However, the idle is still rough. The engine is clearly more shaky than I remember it being last year before I winterized it. I don't notice the shake at higher speeds, but I can feel it when I'm at 1/3 throttle or lower.
Last year, I did not use engine tuner spray before I winterized it. I tried spraying a little combustion chamber cleaner in the air intake yesterday, but it didn't really make a difference. I'm wondering if I should just do a full cleaning as the can instructs. The only reason I'm hesitant to follow the directions exactly is because they tell you to change the engine oil after you spray. I'd rather not do that if I don't have to, because I've only gone about 10 hours since I last changed it.
I'm sure some of you have read my other thread where I also have problems starting up the engine after it sits overnight in cool/dry air (but starts up fine every time after the first attempt in the morning). Rodbolt has suggested that this is due to a problem with my link/sync. So I'm wondering if my rough idle issue is related to my morning startup issue in this way.
Other than using the engine tuner, what should I be looking at? If it's the link/sync, I guess I need instructions for that. The service manual I found doesn't mention anything other than checking the length of the throttle link rod. However, the manual I found is actually from 2004, so maybe there is additional info in the most recent one. If anyone has a link to the service manual for a 2011 F50TLR, I would be most grateful.
For reference, here's my most recent YDIS report from when the engine was started but not yet warmed up:
Diagnosis,
,Code,Item,Result,Condition,
,13,Pulser coil,Normal,,
,15,Water temp sensor,Normal,,
,17,Knock sensor,Normal,,
,18,Throttle position sensor,Normal,,
,19,Battery voltage,Normal,,
,23,Intake temp sensor,Normal,,
,28,Shift position switch,Normal,,
,29,Intake press sensor,Normal,,
,37,Intake air passage,Normal,,
,44,Engine stop lanyard switch,Off,,
,49,Over cooling,Normal,,
Diagnosis Record,
,Total hours of operation,250,
,Code,Item,Occurred,
,29,Intake press sensor,245.4,
Engine Monitor,
,Monitor Item,Result,Unit,
,Engine speed,796,r/min,
,Intake pressure,44.42,kPa,
,Intake pressure,13.27,inHg,
,Atmospheric pressure,990.9,hPa,
,Atmospheric pressure,29.3,inHg,
,Ignition timing,ATDC 11,deg,
,Battery voltage (12-16),14.90,V,
,TPS voltage (0.5-4.5),0.982,V,
,Throttle valve opening (0-90),7.1,deg,
,ISC valve opening,51,%,
,Fuel injection duration,2.31,ms,
,Water temperature (below 90),41.0,°C,
,Water temperature (below 194),105.8,°F,
,Intake temperature (below 70),21.0,°C,
,Intake temperature (below 158),69.8,°F,
,Engine stop lanyard switch,OFF,,
,Shift position switch,ON,,
,Oil press switch,OFF,,
,Dual engine system switch,OFF,,
Data Logger[Engine operating hours according to engine speed],
,Engine speed,Time[h],
,- 1000 r/min,131.9,
,1000 - 2000 r/min,64.7,
,2000 - 3000 r/min,15.8,
,3000 - 4000 r/min,12.1,
,4000 - 5000 r/min,13.0,
,5000 - 6000 r/min,13.3,
,6000 - 7000 r/min,0.0,
,Engine hours,250,
Data Logger[Data comparison graph],
,Engine speed[r/min],Battery voltage (12-16)[V],TPS voltage (0.5-4.5)[V],Water temperature (below 90)[°C],Intake pressure[kPa],Oil press switch[0:OFF 1:ON]
,750,13.18,0.98,62.5,38.5,0,
,1800,13.70,1.25,59.3,54.3,0,
,1900,14.87,1.25,61.7,54.8,0,
,2550,14.79,1.37,61.7,58.2,0,
,1350,14.87,1.09,62.5,42.9,0,
,1750,15.01,1.23,61.7,51.8,0,
,1550,13.77,1.17,61.7,46.4,0,
,1600,15.01,1.17,61.7,46.4,0,
,1000,14.79,1.05,61.7,41.5,0,
,1000,15.01,0.98,62.5,35.0,0,
,850,14.79,1.02,62.5,40.0,0,
,1050,14.94,1.05,62.5,42.4,0,
,850,14.87,0.98,30.4,43.4,0,
And here's a report that was taken after the engine had warmed up for 10 minutes or so:
Diagnosis,
Diagnosis Record,
,Total hours of operation,251,
Engine Monitor,
,Engine speed,738,r/min,
,Intake pressure,36.58,kPa,
,Intake pressure,10.91,inHg,
,Ignition timing,ATDC 9,deg,
,ISC valve opening,31,%,
,Fuel injection duration,1.81,ms,
,Water temperature (below 90),62.5,°C,
,Water temperature (below 194),144.5,°F,
,Intake temperature (below 70),33.3,°C,
,Intake temperature (below 158),91.9,°F,
,- 1000 r/min,132.7,
,Engine hours,251,
,900,14.72,0.98,62.5,42.9,0,
,900,15.09,0.98,62.5,42.0,0,
,900,14.94,0.98,62.5,43.4,0,
,900,14.87,0.98,62.5,41.0,0,
,900,15.01,0.98,62.5,42.9,0,
,900,14.87,0.98,62.5,42.4,0,
,900,14.79,0.98,62.5,42.9,0,
,900,15.01,0.98,62.5,43.9,0,
,900,15.01,0.98,62.5,42.4,0,
,750,14.79,0.98,62.5,35.5,0,
,750,14.79,0.98,62.5,36.0,0,
,750,14.94,0.98,62.5,36.5,0,
The only thing that jumps out at me is that the throttle valve opening is the same for both reports, but the ISC valve opening numbers are different. I also see the ignition timing go from ATDC-9 to 10 to 11.. it jumps between those values when the engine runs. From what I read, that's normal, but maybe there's something else you all can see. Thanks in advance for any advice.
Diagnosis,
Diagnosis Record,
Engine Monitor,
,Engine hours,250,
Diagnosis,
Diagnosis Record,
Engine Monitor,
,Engine hours,251,
