1998 saltwater S175 HP TXRW today with Thermal Temperature gun in hand expecting to find one bank of cylinders clogged causing the overheat alarm ,I’m somewhat convinced that’s not the case . As previously noted new thermostats and water pump were installed spring 2017 boat was used during May and beginning of June when the alarm sounded . Today
Ran the engine at the dock at idle 40 minutes as I keep checking temps 135 -140 the lower cylinders were cooler than the top near the thermostat but remaining 135 -140 increased in neutral to 2500 RPMS 15 minutes keep checking engine temps remained the same on both sides 135 -145 now lowered back to idle keep checking after a few minutes both sides started increasing 140 -150 -160 -170 -180 alarm -190 same on both sides turned off . Let it cool down 25 minutes started reading 125 within minutes increased right back to 190 shut down .
After cooling connected the flush line to a hose but didn’t turn in on now with the engine in the water started the engine and again temps quickly raising I then turned on the hose while the engine was running the temps cooled from 180 to 150 .
So could it be a bad pressure relief valve Poppet ? Arriving today the valve was open or closed confused about the valve but the engine should have overheated well before a hour of running but once that value open or closes it constantly would overheat and quickly just like the day on the water last week ,we traveled 1 ½ miles in a no wake zone no alarm , after a few minutes on plane alarm then letting it cool 20-30 minutes once started at slow speed within minutes back to the alarm and Boat U/S tow.
I ordered Rydlyme Saturday if I had to bring it home as I expected I would , I have a new poppet valve which of course I never installed I turned the nuts so that’s good start I’m over an hour away from the boat but soon I’ll change the valve . What do you guys think ?
