Ok, What is the difference? I cannot locate a data sheet on the vmax. I do know the weight is slightly less. Is this due to corrosion resistant (SS) components in the SWS? Is the gearing/bore/stroke the same? Is the mid-section/lower units interchangeable? Are cowlings interchangeable?
Yamaha OX66 Vmax 250 vs OX66 Saltwater Series 250
Originally posted by rodbolt17 View Postthe ECU's are mapped different.
bold graphics
the vmax is typically 20" and the saltwater series 25 or 30".Last edited by jfbetz01; 06-04-2017, 09:44 PM.
Got it. However, it would seem easier just to have all use ccs, or all not. I actually hear more complaints about a rough low rpm shake b/c of ccs. As long as all else is in tune, shouldn't be much of a bother.
Btw, I think I read somewhere that the flair on the max cowl was so e type of ad-hoc ram air design. Sounds like all theory...Last edited by jfbetz01; 06-04-2017, 11:23 PM.
Originally posted by jfbetz01 View PostGot it. However, it would seem easier just to have all use ccs, or all not. I actually hear more complaints about a rough low rpm shake b/c of ccs. As long as all else is in tune, shouldn't be much of a bother.
Back to reality, the VX250 uses a Showa power trim and tilt unit which IMO is a slightly less robust component.
Yam says both models use CCS. I don't know.
Originally posted by pstephens46 View PostRam Air just for looks? Thought I read somewhere years ago that intakes and carbs do not like turbulent air.
A VX driver has to be cautious with throttle application, lest the boat and motor get away from him.
Originally posted by 99yam40 View Postand watch out for live/bait wells throwing water at the motor ramming some of that too
If fresh water then more power will be made. If saltwater more power will be made but the metal parts don't like it so much.
Actually, there should be a caution not to be within so many feet of the air intake system when the motor is running. Like the intake of a jet airplane.
Frozen chickens would be a problem. Fresh dead chickens is what are used I believe. Into engines, radomes and windscreens.
There is nothing worse than having buzzard guts in ones lap whilst one is trying to alight the aeroplane at the aerodrome. Tower, we have a bit of a slight problem here in the **** pit.
A buzzard by the way that recently gorged him/herself old days on road kill. Yummy.
They report that there is nothing left that can be identified as a chicken by the way.
ÂÂ
